Old 10-23-2009, 03:56 PM
billjarrold billjarrold is offline
Sorry, one more thing....I now see that when you asked me to send the resetHeading code I had used last night, there is a much simpler way to interpret your request.
I will now follow that much simpler interpretation...
This is the simple test program last night I wrote containing resetHeading. (You'll see I took your program and commented out the stuff I thought was not needed) My guess is that the problem is that I did not do an addTracker....farther below you will see the output to running this program (there were no errors).....
#Add ground
# ground = viz.add('tut_ground.wrl')
#Add intersense
PORT_INTERSENSE = 1
isense = viz.add('intersense.dls')
#Add node
#node = viz.add('marker.wrl')
#node.translate(0,1.5,4)
#viz.startlayer(viz.LINES)
#viz.vertexcolor(viz.RED)
#viz.vertex(0,0,0)
#viz.vertex(0,0.5,0)
#viz.endlayer(parent=node)
#Link sensor to node
#link = viz.link(isense,node)
#Create keyboard events
vizact.onkeydown('r',isense.reset)
#vizact.onkeydown('1',link.reset,viz.RESET_ORI_LOC AL)
#vizact.onkeydown('2',link.reset,viz.RESET_ORI_WOR LD)
#vizact.onkeydown('3',link.reset,viz.RESET_ORI_RAW )
.......This is the output when I ran that program and hit 'r' key a few times waiting about 1 second in between each press of the 'r' key.....
** Loading junk-test-reset5.py
intersense.dls Intersense Driver v4.0.4
**Connected to Intersense device on port 1
Type: IS Precision Series
Model: Unknown
Station State Time Cube Enhancement Sensitivity Compass Prediction
1 ON ON 1 2 3 2 0
** Load Time: 3.83 seconds
InterSense Library ver. 4.04 32-bit
Copyright 1998-2007 InterSense Inc.
http://www.intersense.com
Tel: 781-541-6330
Looking for InterSense tracking device number 1.
Please wait ...
IC2 Plus device detected
