Thread: Network format
Old 10-23-2009, 11:29 AM
The data that is transmitted by Vizard is pickled using the cPickle module. To get access to the data on your end you can use the following code:
data = cPickle.loads(rawData)
The variable data should be a tuple containing:
  1. The senders computer name
  2. A tuple containing the positional data from the <network>.send() command
  3. A dictionary containing keyword data from the <network>.send() command
