Old 10-18-2009, 07:42 PM
atamasan atamasan is offline
I have solved the problem by myself.
Thank you.
But I've got another question.
When I use <node3d>.collideSphere, the command usually work great. But when I change the scale of the node(especially, when I make the node small), collideSphere doesn't work.
For example,,,
ground=viz.add('shpere_ground3.ive')
ball=viz.add('white_ball.wrl')
ball.setScale(.1,.1,.1)
ball.setPosition(0,.5,0)
ball.collideSphere()
In this case, collision doesn't happen(ball falls down through ground). But if I change the scale of the ball(I make the ball bigger like [2,2,2]), collision can be seen.
What is the reason for this? Please give me some advice.
Thank you for reading.
