Old 10-16-2009, 01:19 PM
You won't be able to create a perfect circle using bezier paths. You are better off manually animating the object. Either way, the following modified version of your script will generate a path that is closer to a circle. It uses cubic bezier and you removes the duplicate control point at the end of the path:
import vizmat
viz.add('tut_ground.wrl')
ball = viz.add('ball.wrl')
viz.MainView.move([0,3,-20])
path = viz.addAnimationPath()
positions = [ [0,1,10], [10,1,0], [0,1,-10], [-10,1,0] ]
for x,pos in enumerate(positions):
	cp = viz.addControlPoint()
	cp.setPosition(pos)
	path.add(cp,x+1)
path.loop(viz.CIRCULAR)
path.translatemode(viz.CUBIC_BEZIER)
path.computetangents()
path.setAutoRotate(viz.ON)
mylink = viz.link(path,ball)
path.play()
def PrintInfo():
	pc = ball.getPosition()
	print 'position: ', pc
	dist = vizmat.Distance(pc,[0,1,0])
	print 'distance: ', dist
vizact.ontimer(0,PrintInfo)
