Navigating an avatar using mouse position(2D) in 3D environment
I am trying to navigate an avatar using mouse e.dx and e.dy position in 3D environment.
Could you give any idea to how use e.dx and e.dy to solve the problem?
James
(on viz.MOUSE_MOVE_EVENT event, I am having e.dx and e.dy
e.dx
The relative movement of the mouse in the X direction. The value is in raw mouse units. Negative values indicate the mouse was moved to the left. Positive values indicate the mouse was moved to the right.
e.dy
The relative movement of the mouse in the Y direction. The value is in raw mouse units. Negative values indicate the mouse was moved downward. Positive values indicate the mouse was moved upward.
