Thread: NetBeans IDE
Old 10-09-2009, 10:44 AM
You should be able to develop Vizard scripts using any IDE you wish. In order for the scripts to be properly executed, you need to tell the IDE to launch your script using winviz.exe in the Vizard/bin folder. Most IDEs I've encountered allow you to modify the command line for script execution, so I'm assuming this should also be possible with NetBeans.
