Old 09-28-2009, 05:26 PM
The vizact.spinto action will take the shortest path to reach the target orientation. If you are turning 360 degrees, then the shortest path is to do nothing.
Instead, use the vizact.spin action and calculate the duration and speed so the end result is 360 degrees ( speed * duration = 360 ).
