Old 09-28-2009, 05:11 PM
vijaykiran vijaykiran is offline
Unable to perform 360 rotation using vizact.spinto
I am trying to make an object perform a single spin action for 360 degrees followed by a forward motion. The following piece of code doesn't seem to help and the object just stays put.
model = viz.add('object.ive')
spinToYaw = vizact.spinto([0,1,0, 360], 50)
moveForward = vizact.move([0,0,4], 5)
model.addAction( spinToYaw )
model.addAction( moveForward )
I am however able to get up to 180 degrees of rotation with:
spinToYaw = vizact.spinto([0,1,0, 180], 50)
Any more than 180 degrees spins the object in the opposite direction:
spinToYaw = vizact.spinto([0,1,0, 181], 50)
To perform a 360 degree rotation, I thought i could get lucky if I run yaw actions two times using:
The above did nothing but rotate the model by 180 degrees and then immediately moved forward as defined in
moveForward
action. The second call to
did not make any difference.
On the other hand, if I have a different axis for spinto as in the code below:
spinToRoll = vizact.spinto([0,0,1, 180], 50)
model.addAction( spinToRoll )
So, here are my two questions:
1) I get a 180 degree yaw, followed by 180 degree roll and then forward movement. If this logic works, then shouldn't two 180 degree yaws work as a 360 degree rotation ?
2) If there is a reason why two 180 degree yaws will not equal to a 360 degree rotation, what do I need to do to obtain just one single 360 degree rotation followed by another action. I do not want to use viz.FOREVER because it will keep on spinning the model.
Vijay.
