Old 09-23-2009, 10:37 AM
Yes, Vizard will run on Windows Vista/7 64-bit. Keep in mind that Vizard is still a 32-bit application, so it won't be able to take advantage of 64-bit hardware (i.e. use more than 4 GB of memory). Also, if you are using any hardware devices with Vizard you will need to use the 64-bit version of the device drivers.
