Old 09-09-2009, 01:12 PM
You should use the viztask module to generate screenshots within a loop. Simply yield one frame in between screenshots and they should all be saved correctly. Here is a sample script:
import viztask
model = viz.add('vcc_female.cfg',pos=(0,1,3))
def ScreenShotTask():
	for x in range(10):
		#Rotate model
		model.setEuler(x*36,0,0)
		#Request screen capture at end of frame
		viz.window.screenCapture('image%02d.bmp'%(x))
		#Wait for frame
		yield None
viztask.schedule( ScreenShotTask() )
