Old 08-28-2009, 03:14 PM
3DS files contain material information, including texture images. So the file is probably referencing that tga file. The file might already exist in the 3ds Max directory. That might explain why it doesn't produce an error message.
Regarding scaling, Vizard uses meter units. So you might need to adjust your 3ds Max settings to use the same units.
