Thread: VizUtils
Old 10-04-2004, 11:14 AM
kim_swinth kim_swinth is offline
VizUtils
Hi Farshid (and all)...
I am having a problem with the VizUtils module that I'm hoping you can help me with.
I've attached a sample script that I wrote for ATI called "Avatar_Inspection_Experiment" that uses VizUtils.
When the world loads, hit the "S" key to start the program.
You'll notice that an avatar appears with a Likert scale over his/her head and participants are asked to make a rating about the avatar.
The problem is, the numbers for the scale don't show up. It looks like a problem with z-buffering or something, but I've played around with the parameters in the VizUtils script quite a bit and can't seem to get the problem fixed. If I navigate around with my mouse, then I can see the numbers, but you shouldn't have to do that.
I'd like to use something similar on an experiment I'm running this quarter, but need to get the z-buffering (or whatever problem it is) fixed first.
Any ideas about what is wrong?
I'm also having problems with the "SaveData" function in VizUtils. I want to create a unique datafile for each participant (which I am able to do). But I can't get the program to NOT make a default file (which in this case is called "TrackingData"). The main problem is that the "TrackingData" file does not ever seem to get released unless I actually exit Vizard. Any idea why?
Thanks in advance for your help!
Kim
