Old 08-18-2009, 11:33 PM
atamasan atamasan is offline
Question Problem of hand model(using sensors).
Hello.
I'm trying to move hand model using 16 patriots(for my right hand).
So I made codes and run the codes. But the result was not good.
Fingers bends to the strange direction.
I tried to solve the problems, and I think there are problems in my initialization part. But I couldn't find them.
Could you please tell me hint?
This is the flow of my codes.
import math
right_h=viz.add('hand.cfg')
#get 16 sensors
pat01=viz.addSensor('patriot')
pat16=viz.addSensor('patriot')
#get hand bones
rbt_00=right_h.getBone('bone thumb 0-0')
rb=right_h.getBone('bone ~ROOT')
#calculate inverse matrix from sensors's data, manually(if framenumber=1)
inv01~inv16
#make rotation matrix from each sensor's data
Rrot01~Rrot16
#Multiplication
R_01=inv01*Rrot01
R=16=inv16*Rrot16
#get Euler angles for each sensor from the Matrix(R_01~R_16)
#and link Euler angles to each sensor
l_r_01=viz.link(pat01,rbt_01)
l_r=viz.link(pat16,rb)
#finally, use the MASK command(Because I need only ORIENTATION DATA)
l_r_01.setMask(viz.LINK_ORI)
l_r.setMask(viz.LINK_ORI)
[FIN]
I think I should do that more easily, but I'm confused now...
Thank you for reading my message.
