Old 08-14-2009, 04:16 AM
jaclyn.bill jaclyn.bill is offline
Meaning of Errors
Dear users,
I have a script which appears to be working fine but is throwing up the following error related to my "setting an animation path for passive steering" section in the script below. Is this related to only two points being at the beginning and end points of my animation path? as when I print out these control point locations the error isn't consistent with this and I want to be sure it's dropping frames.
** WARNING: Need at least three control points to calculate tangents
Also, in starting line 71 of this code I want compute the heading angle of the road positioning. Is there a command in vizard similar to the viz.MainView.getEuler which I can use before the viewer sets off down the path, as I want to drop objects on the scene relative to heading (e.g. if they are heading right the object is on their right etc.). My attempts at this manually (commented) have resulted in the error "unsubscriptable object"
import math
import viztask
import random
import vizjoy
from numpy import *
import numpy as np
######## refreshes/ params etc
REPS = 60.00  ####screen refresh rate
TRIALLENGTH = 16.0 ##### block length
INC = 0.0166 ##### increment (1sec/refresh rate)
SPEED = 8  #####m/s
XVARY= [0.9,1.1]
POINTS = REPS*TRIALLENGTH ####determines detail of sine wave
METERS = TRIALLENGTH*SPEED #### how many meters travelled (linear)
PTOM = POINTS/METERS  #### points to meter ratio
NUM_CONES = 5
####### road parameters
XEXTENT = 5.0 ### furthest extent of road
ZCOORD = linspace(0.0, METERS,POINTS) #### z coords 0 - meters
XCOORD = cos(ZCOORD/18.0)*XEXTENT*sin(ZCOORD/10.0)
YCOORD = [0.25 for y in range(POINTS)] ##### y should be fiexed amount off the ground
positionlist = []
A = random.randint(8*PTOM,11*PTOM)
B = random.randint(16*PTOM,45*PTOM)
C = random.randint(50*PTOM,77*PTOM)
D = random.randint(81*PTOM,108*PTOM)
E = random.randint(113*PTOM,120*PTOM)
YS = 0.25
cones = []
####### viewpoint stuff
viz.clearcolor(viz.SKYBLUE)  ##### sky colour
viz.MainView.getPosition() ###### get potition of main viewpoit
view = viz.get(viz.MAIN_VIEWPOINT)  ##### get position of main viewpoint
### setttin ground plane
NUMBER_OF_REPEATS = 100
gravel = viz.add('gravel.jpg',wrap=viz.REPEAT)
ground.setPosition(0,0,25)
ground.setScale([100,100,100])
ground.collidePlane()
ground.texture(gravel)
ground.texmat( viz.Matrix.scale(NUMBER_OF_REPEATS,NUMBER_OF_REPEATS,1) )
viz.clip(0.1,200)
##setting an animation path for passive steering
####################creates the points for the path
def createpath():
	global path,cp,positionlist,x,y,z,XDIFF,ZDIFF,ang
	for i in range(0,POINTS):
			x=XCOORD[i]; z= ZCOORD[i]; y=YCOORD[i]
			positions = [x,y,z]
			positionlist.append(positions)
	for m in range(0,POINTS-1):
			XDIFF = XCOORD[m+1]- XCOORD[m]
			ZDIFF = ZCOORD[m+1]- ZCOORD[m]
			#ang = math.atan(ZDIFF/XDIFF)
			#heading = ang[m+1]-ang[m]
			#print heading
createpath()
################# defines the control points and movement through these
def controlpoints():
	global path
	path = viz.add(viz.ANIMATION_PATH)
	for dist in range(0,len(positionlist)):
		cp = viz.add(viz.CONTROL_POINT)
		cp.setPosition(positionlist[dist])
		path.add(cp,dist+1)
		path.constantspeed(viz.ON,SPEED)
		path.loop(viz.OFF)
		path.computetangents()
		path.translatemode(viz.LINEAR)
		path.setAutoRotate(viz.ON)
		viz.link(path, viz.MainView)
controlpoints()
########################### plays the path when space is pressed
def playpath(key):
  if key == ' ':
    path.play()
viz.callback(viz.KEYDOWN_EVENT,playpath)
###### drop objects on the scene
pole = viz.add('pole.wrl')
pole.color(1,0,0)
pole.setPosition(positionlist[959])
moveleft = vizact.move(-0.5,-0.25,0,1)
moveright = vizact.move(0.5,-0.25,0,1)
def placecones():
	global cone, pos
	for place in (positionlist[A],positionlist[B],positionlist[C],positionlist[D],positionlist[E]):
		pos = (place)
		cone = viz.add('pole.wrl',cache=viz.CACHE_CLONE,pos=pos)
		cone.color(0,1,0)
		cone.setScale(2,0.05,2)
		cones.append(cone)
		if pos[0]>0:
			cone.addAction(moveleft)
		if pos[0] <0:
			cone.addAction(moveright)
placecones()
####movement params with keyboard
MOVE_SPEED = 7
TURN_SPEED = 30
def steering(num):
	if viz.iskeydown(viz.KEY_UP):
		view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
	elif viz.iskeydown(viz.KEY_DOWN):
		view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
	if viz.iskeydown(viz.KEY_RIGHT):
		view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
		view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
viz.callback(viz.TIMER_EVENT,steering)
######### Running the trials
logFile = open ('OBJECTAVOIDENCE_OUTPUT.txt','w')
def Mainviewpos():
	currentTime = viz.tick()
	pos=viz.MainView.getPosition()
	angpos=viz.MainView.getEuler(viz.VIEW_ORI)
	save = ( str(currentTime*1000) + '\t' + str(pos[0])+ '\t' + str(pos[1]) + '\t' + str(pos[2])+ '\t' + str(angpos[0])+ '\n')
	logFile.write(save)
Mainviewpos = vizact.onupdate(0,Mainviewpos)
