Thread
Turn around the y-axis
1
07-20-2009, 09:44 AM
farshizzo
You can use the
<node>.center()
command to set the pivot point for rotation. For example, if you wanted to rotate the line around the first vertex, you would use the following code:
vec1.center(2,3,5)
farshizzo
View Public Profile
Find all posts by farshizzo
