Old 09-21-2004, 11:30 AM
Take a look at the <viewpoint>.gotomode and <viewpoint>.pivot commands. Also, there is an example script in the [Vizard20]/examples/advanced directory called animateview.py which shows how to use these functions.
Basically what you would want to do is something like the following:
def outofmymind(): # animate a smooth POV transition
	myApos = myAvatar.get(viz.POSITION)
	myPOV = viz.get(viz.MAIN_VIEWPOINT)
	myPOV.gotomode(viz.BLEND_ROTATE) #Also try out 	viz.PIVOT_ROTATE, see which one you like better
	myPOV.pivot(myApos)
	myPOV.goto(5,5,5,.85) #just an arbitrary external place
To format some text as code you can press the button with the "#" symbol or you can manually add the following tags around it: [ code ]some code[ /code ]
