Old 06-26-2009, 08:08 PM
Assuming you are doing collision detection with the "collision(viz.ON)" function, you could wait for a viz.COLLISION_EVENT notification.
def onCollision(info):
    print 'Collided with object',info.object
    #stop view until joystick impulse direction vector points over 90 degrees
    #away from info.normal
viz.callback(viz.COLLISION_EVENT, onCollision)
You know your needs better of course, but why not just let the user zero the joystick if they don't like moving around the circle? Perhaps you want is to create a "dead zone" for the joystick input. So if input is less than .05 away from zero, then impulse is 0.
