Jittering issue
We currently have a system set up with two LEDs, and an InertiaCube2. We are using the "Optical Heading" plugin in PPT but this is causing us some jittering in the yaw value. We have placed the headset on a flat surface, but the values continue jitter back and forth. We then turned off the effect of the LEDs on the Yaw value and it stopped jittering. Is there any possible way to fix this? (Note: We are using a 3 camera system at the moment. One is being fixed.)
Vic
