Old 06-10-2009, 01:31 PM
You loop should work, but there is no connection between it and your callbacks. It loops through and then leaves Trial set to a value of 8. If you want Trial to update each time a key is pressed then increment it in your keyboard callback function.
Trial = 0
def onKeyDown(key):
	global Trial
	Trial += 1
viz.callback(viz.KEYDOWN_EVENT, onKeyDown)
