Old 06-09-2009, 12:33 PM
Hi Omadawn,
I've seen this problem before, but I don't currently recall the solution. Could you send us a copy of a corrupted image file that is produced when you export to .OSG?
As a quick fix, if you export to OSG using TGA, then you should be able to go into the images directory and manually replace the corrupted TGAs with the original ones. Just make sure to turn off "save texture images" for further exports and copy them manually.
