tracking position of cursor
I have a four wall CAVE system with four Flock of Birds trackers using trackd. I am able to start the tracking system using: tracker = viz.add('trackd.dls') and viz.tracker(). For some reason, the system is only tracking the sensor corresponding to the user's head position. Which isn't necessarily a bad thing because now I have a head tracked virtual environment.
However, I would still like to be able to use more than one sensor.
I want to attach one of the sensors to a gamepad device and have a virtual cursor that will allow me to interact with objects in the environment. I have tried using the tracker.get() command but have not been having any luck.
Thanks in advance for the help
sl0bz
