Old 09-16-2004, 12:25 PM
The trick is to use a timer to check if the key is down. Here's some sample code:
ROTATION_SPEED = 20.0 #Degrees/second
def ontimer(num):
	if viz.iskeydown(viz.KEY_RIGHT):
		view.rotate(0,1,0,ROTATION_SPEED*viz.elapsed(),viz.HEAD_ORI,viz.RELATIVE_LOCAL)
		view.rotate(0,1,0,-ROTATION_SPEED*viz.elapsed(),viz.HEAD_ORI,viz.RELATIVE_LOCAL)
