					Originally Posted by farshizzo  If you detach one of the children from the parent, then the transformation won't be applied to the node, and it will go back to using a Z-up convention. |
 I understand that when I detach a child that it will go back to a Z-up convention. But when I reattach the child to the same parent, shouldn't it be in a Y-up position again?
Greetings, Joran.
