Thread: 16:9 output
Old 05-20-2009, 10:06 AM
You might need to adjust the aspect ratio to account for the new projector size. By default, Vizard computes the aspect ratio to match the size of your screen, so you shouldn't have to change anything and it will work. If you have manually specified your own aspect ratio, then you will need to change that in your code. If you have used the viz.fov command in your code, then the second parameter controls the aspect ratio. If you set the value to viz.AUTO_COMPUTE then Vizard will determine the proper aspect ratio for you.
