if you have PPT-X cameras, the plugin you need to use is the one for PPT-X.
the ppt-x range is not limited to 15feet, in fact we have customers who use Ppt-x all the way out to some 40 or 50 feet.
functionality in this case simply depends on how well you can control your lighting conditions,
how many points you need to tack (for PPT with Marker-ID or PPT-Mocap, rooms with less than 30feet x 30feet are better).
PPT-H are higher-resolution cameras, and also process the signals on-board, so the signal quality is not dependent on cable length, which is why PPT-H is ideal for really large rooms and/or high-speed tracking (PPT-H is 180Hz!)
hope that makes it clear!
have fun!
