Old 09-15-2004, 01:09 PM
The only format that supports particle effects within Vizard is .osg
There is a plugin for 3dsmax that exports to this format, however I don't think this plugin supports particle effects. Currently, the only way to create a particle effect is to hand edit your own .osg file. If you're still interested I can supply you with an example.
