Old 05-12-2009, 01:04 PM
Dance party test
Here is an avatar stress test script. Sliders control the number of avatars and the update rate.
MAX_AVATARS = 100
START_COUNT = 10
viz.MainView.setPosition([0, 1.5, -5])
viz.window.framerate(viz.NICE)
#dance beat
music = viz.add('carousel.wav',volume=0.15,loop=1)
music.play()
avatars = []
updateRate = 0
def addAvatar():
	a = viz.add('vcc_female.cfg')
	a.state(5)
	a.setPosition([.5*len(avatars), 0, 0])
	a.updaterate(updateRate)
	avatars.append(a)
for i in range(START_COUNT):
	addAvatar()
def removeAvatar():
	avatars.pop().remove()
import vizinfo
info = vizinfo.add('')
avatarSlider = info.add(viz.SLIDER, 'avatar count  '+str(START_COUNT))
updateRateSlider = info.add(viz.SLIDER, 'update rate 0   ')
def onAvatarSlider(pos):
	targetCount = int(pos * MAX_AVATARS)
	avatarSlider.label.message('avatar count: ' + str(targetCount))
	countDiff = targetCount - len(avatars)
	if countDiff > 0:
		#add avatars
		for i in range(countDiff):
			addAvatar()
		#subtract avatars
		for i in range(-countDiff):
			removeAvatar()
vizact.onslider(avatarSlider, onAvatarSlider)
def setUpdateRate(rate):
	global updateRate
	updateRate = rate * .2
	updateRateSlider.label.message('update rate' + str(round(updateRate, 3)))
	for a in avatars:
vizact.onslider(updateRateSlider, setUpdateRate)
