Draw Line between Points
I want to create a line between two points. The first point at the mouseDown Position and the second point at the mouseUp Position. Between these two points I want to draw a line.
This works very fine.
But now I want to show the line, before the mouseUp Event. So that I push down the mousebutton, move it at another position and can already see the line, although the mousebutton is pushed.
The line would change as long as I push the mousebutton.
Is this possible?
Thanks in advance...
