Old 09-15-2004, 12:44 PM
I've attached a sample script that simulates an infinite terrain. The basic idea is to modify the texture coordinates on a tiled texture to make it look like the ground is moving. Let me know if something isn't clear.
SIZE = 1000.0
#Create a ground on the fly
ground.scale(100,100,100)
def ontimer(num):
	#Keep the ground at the same xz position as the head
	pos = viz.get(viz.HEAD_POS)
	ground.translate(pos[0],0,pos[2])
	center = [ (pos[0] % SIZE) / SIZE, (pos[2] % SIZE) / SIZE ]
	#Translate and scale texture coordinates
	texmat = viz.Transform()
	texmat.setTrans(center[0],center[1],0)
	texmat.setScale(0.5,0.5,1)
	ground.texmat(texmat)
viz.translate(viz.HEAD_POS,0,50,0)
viz.sensitivity(10,1)
