Old 05-10-2009, 03:47 PM
You could apply a small force opposite the direction the ball is moving. Here a function is called ten times, the first nine times getting the velocity of the ball and applying a small force opposite to it. On the tenth time the ball is stopped completely.
viz.phys.enable()
ground.collidePlane()
ball = viz.add('ball.wrl', pos = [0,1,8])
ball.collideSphere()
ball.applyForce([2,0,10], .1)
num = 1
def slowBall():
	global num
	#slow down the ball
	if num <10:
		vx,vy,vz = ball.getVelocity()
		ball.applyForce([-vx,-vy,-vz], .01)
		num+=1
	#stop the ball
		ball.setVelocity([0,0,0])
		ball.setAngularVelocity([0,0,0])
#call function 10 times
vizact.ontimer2(.3,9, slowBall)
