Old 05-06-2009, 09:23 AM
Specular Shader Issue
I was wondering if I could get a help with a Specular Shader problem.
I made a shader in the program AMD RenderMonkey, which if you are not familiar with is a 'sandbox' for making shaders and testing them out.
Everything works fine in RenderMonkey, but I run into the issue of nothing
rendering when I move into Vizard.
My Vertex Shader is:
//Uniform
uniform vec3 LightPosition;
uniform vec3 EyePosition;
//Varying
varying vec3 ViewDirection;
varying vec3 LightDirection;
varying vec3 Normal;
varying vec2 Texcoord;
//Attributes
void main(void)
   gl_Position = ftransform();
   Texcoord = gl_MultiTexCoord0.xy;
   vec4 objectPosition = gl_ModelViewMatrix * gl_Vertex;
   LightDirection = (gl_ModelViewMatrix * vec4(LightPosition, 1)).xyz - objectPosition.xyz;
   ViewDirection = EyePosition - objectPosition.xyz;
   Normal = gl_NormalMatrix * gl_Normal;
My Fragment Shader:
uniform vec4 Diffuse;
uniform vec4 Ambient;
uniform vec4 Specular;
uniform float SpecularPower;
uniform sampler2D TexMap;
uniform sampler2D SpecMap;
void main(void)
   vec3 nLightDirection = normalize(LightDirection);
   vec3 nNormal = normalize(Normal);
   float NDotL = dot(nNormal, nLightDirection);
   vec3 Reflection = normalize(((2.0 * nNormal) * NDotL) - nLightDirection);
   vec3 nViewDirection = normalize(ViewDirection);
   float RDotV = max(0.0,dot(Reflection, nViewDirection));
   vec4 diffColor = texture2D(TexMap,Texcoord);
   vec4 specColor = texture2D(SpecMap, Texcoord);
   vec4 DiffuseColor = diffColor * Diffuse * NDotL;
   vec4 AmbientColor = Ambient * diffColor;
   vec4 SpecularColor = (Specular * (pow(RDotV, SpecularPower))) * specColor;
   gl_FragColor = DiffuseColor + AmbientColor + SpecularColor;
And my Vizard code for bringing in the shader and attaching it to the model:
shader = viz.addShader(flag = 0, vert = "SpecMap.vp", frag = "SpecMap.fp")
viz.MainView.eyeheight(0.0)
#Load model
trex = viz.add("TREX//TRex.CFG")
trex2 = viz.add('sphere.obj')
trex2.setPosition(15,0,0)
#Load Textures
TexMap = viz.addTexture('TRexTex_10_TexMap.bmp')
SpecMap = viz.addTexture('TRexTex_10_SpecMap.bmp')
#Attach textures
trex.texture(TexMap, '', 0)
trex.texture(SpecMap, '', 1)
trex2.texture(TexMap, '', 0)
trex2.texture(SpecMap, '', 1)
#Vertex Uniforms
EyePosition = viz.addUniformFloat('EyePosition', [0.0,0.0,0.0])
LightPosition = viz.addUniformFloat('fvLightPosition', [100,200,100])
#Fragment Uniforms
Diffuse = viz.addUniformFloat('Diffuse',[1.0,1.0,1.0,1.0])
Ambient = viz.addUniformFloat('Ambient',[1.0,1.0,1.0,1.0])
Specular = viz.addUniformFloat('Specular', [1.0,1.0,1.0,1.0])
SpecularPower = viz.addUniformFloat('SpecularPower', 3)
Texture =  viz.addUniformInt( 'TexMap', 0 )
SpecularMap = viz.addUniformInt( 'SpecMap', 1 )
shader.attach(Texture)
shader.attach(SpecularMap)
trex.apply(shader)
trex2.apply(shader)
