Old 04-27-2009, 06:15 PM
The following code creates a mousetracker object from the Viztracker module. The hand gets linked to this mousetracker. When you pick an object it gets linked to the hand.
import viztracker
tracker = viztracker.MousePos()
#Add the object that will do the grabbing and link it to the tracker
hand = viz.add('marker.wrl')
viz.link(tracker, hand)
#turn off mouse navigation
viz.mouse(viz.OFF)
#Add the object that the marker will grab
ball = viz.add( 'ball.wrl' )
ball.translate( 0.5, 1.5, 3 )
link = None
#Grab or let go of the ball
def toggleLink():
	global link
	if link:
		#If link exits, stop grabbing
		link.remove()
		link = None
	elif vizmat.Distance(hand.getPosition(), ball.getPosition()) < .5:
		link = viz.grab( hand, ball )
vizact.onpick(ball,toggleLink)
