Old 04-13-2009, 12:01 PM
Perhaps the door was offset from the origin in your modeling software. If you just spin the model without changing it's center in Vizard and its moving all over the place then that would be the case.
If you set the origin of the door in your modeling software to the point that you want the door to rotate around then you don't have to change it's center in Vizard
