Old 04-10-2009, 12:27 AM
As Jeff pointed out, the message receiver needs to do different things depending on the message type.
For flexibility, try adding a 'messageType' variable to all your <mailbox>.send() calls. That way you can check the 'messageType' in your 'onNetwork' function then access the variables you know come with specific message types.
CREATE_PERSON_NETWORK_EVENT = 1
UPDATE_PERSON_NETWORK_EVENT = 2
def personJoined():
    mailbox.send(messageType=CREATE_PERSON_NETWORK_EVENT, avatarFileName='blabla.cfg')
def sendPersonData(person):
    mailbox.send(messageType=UPDATE_PERSON_NETWORK_EVENT, euler=...
def onNetwork(e):
    if e.messageType == CREATE_PERSON_NETWORK_EVENT:
        viz.add(e.avatarFileName)
    elif e.messageType == UPDATE_PERSON_NETWORK_EVENT:
        otherPerson.setEuler(e.euler)
Also, the viznet.py module will help you create more robust networked applications.
Jeff or Farshizo can you post that *sweet* viznet demo with the boxes and springs?
Paul Elliott
WorldViz LLC
