Old 09-13-2004, 08:28 PM
tobin tobin is offline
An avatar is a subclass of a node3d object. If you look under the help "command reference" for node3d objects, you'll see a method called "get". It can get the position along with many other states of any valid node3d object. Refer to the docs for syntax.
