Old 04-01-2009, 10:38 AM
sjp sjp is offline
intersense with 5DT glove
I tried connecting my 5DT glove to my system to run the turbine demo, but can't seem to get the system to recognize the intersense connected to the glove. I'm almost positive that this worked last time I tried (months, maybe years ago).
The glove intersense port is the same one I've always used (port 3), and I'm pretty sure I hooked up all of the cables correctly. The intersense from the HMD can't be interfering somehow, can it? I can't remember ever having to disconnect it.
Here's my error message (I realize that this time it also didn't connect to PPT, but I'm not having that problem anymore); any thoughts? Thanks!
** Loading engine_grab.py
Loading File: groundgrid.wrl
intersense.dls Intersense Driver v2.1
vizppt.dls WorldViz PPT v3.0
5dt.dls 5DT Glove Driver v1.0
** ERROR: Failed to connect to intersense on port 3.
PPT: cannot open serial port: No such file or directory
** ERROR: Failed to connect to PPT
** NOTIFY: Connected to 5DT DG5 Ultra USB on USB0
Loading File: hand.cfg
** WARNING: <node>.spin will be deprecated in future versions of Vizard, use vizact.spin instead
Loading File: frontshell.ive
Loading File: frontfan.ive
Loading File: backfan.ive
Loading File: backshell.ive
Loading File: pipes.ive
** Load Time: 1.47 seconds
Scaling image 'images\nosecone.tga' from (295,295) to (256,256)
InterSense Library ver. 4.04 32-bit
Copyright 1998-2007 InterSense Inc.
http://www.intersense.com
Tel: 781-541-6330
Looking for InterSense tracking device number 1.
Please wait
InterSense tracker not present
