eMagin disconnecting after time has passed/after a sound has played
I am having a bit of a problem with the orientation sensor in the eMagin VR glasses. At a somewhat random interval, I lose contact with the glasses. If I use vizact.speech actions, I can make it fail a lot faster. I tried <sensor>.reset(), but that appears to set the current orientation to [0,0,0]. Is there a way using command() or some other function to disconnect and reconnect with the glasses?
Christian
