Old 09-08-2004, 08:32 PM
mspusch mspusch is offline
Not sure it should have clear things up because I just looked at Photovista 1.3 and it does in fact support cube map exporting so I was wrong. I tried it and it puts all 6 maps in one image, stacked vertically.
You could fairly easily write a Photoshop "action" that would resize it first to say 512 x 3072 (6*512) and then pull out each of the size sections into separate documents. All you need to do is follow the naming convention given in the Vizard tutorial on creating panoramas.
