Old 03-14-2009, 11:24 AM
dan12345 dan12345 is offline
viz.message position
Hi
I'm running an experiment, and i would like at the end of it to show a message to the screen - not to the hmd... Since i ran the experiment with the hmd, i had to double the size of the screen, from the usual 1024x768, so it would show the stereo nicely in the helmet. The problem, is that then when i show the message (using viz.message), it show the message at the right of the computer screen, instead of the middle of it, because of the resolution.
so - is there a way to decide the posion of the viz.message output ( to change it so it won't be in the middle, but to the left ) ? for some reason just changing back the resolution didn't work ( maybe because i ran the experiment using viz.go(HMD|STEREO) )
