Old 03-14-2009, 05:17 AM
levisii levisii is offline
oh, i'm sorry. first time i'm posting here
i've splitted my code to one files per class, but if you run this, it is showing my problem:
import viz, wx
#This class implements the GUI-Frame
class MainFrame(wx.Frame):
    def __init__(self, parent, id, title):
        wx.Frame.__init__(self, parent, id, title)
        #Menubar
        menubar 	= wx.MenuBar()
        worldViz 	= wx.Menu()
        worldViz.Append(104, '&Simulation', 'Start a 3D-simulation')
        menubar.Append(worldViz, '&WorldViz')
        self.SetMenuBar(menubar)
        self.CreateStatusBar()
        wx.EVT_MENU(self, 104, self.onStart3D)
    #calls the embedded simulation
    def onStart3D(self, event):
        self.timer = wx.Timer(self, 5000)   #Timer for updating the frames
        self.timer.Start(10)
        wx.EVT_TIMER(self, 5000, self.onTimer)
        viz.go(viz.EMBEDDED)
        simulation()
    #Manuel FrameUpdate
    def onTimer(self, event):
        viz.updateframe()
#this is my test simulation
def simulation():
    viz.clearcolor(0.5, 0.5, 1.0)
    #Set ViewPoint
    view = viz.MainView
    view.setPosition(0, 1, -20)
    #Turn on the physics engine
    viz.phys.enable()
    #Add ground
    ground.collidePlane()
#Exit-function
def onkeydown(key):
    if key == '1':
        print 'onKeyDown() executed'
        viz.quit()
viz.callback(viz.KEYDOWN_EVENT, onkeydown)
def onexit():
    print'onExit() executed'
    viz.quit()
viz.callback(viz.EXIT_EVENT, onexit)
#this is the starting class
class MainApp(wx.App):
	def OnInit(self):
		frame = MainFrame(None,-1, 'Phantom')
		frame.Show(True)
		return True
app = MainApp(0)
app.MainLoop()
del app
