Old 03-13-2009, 10:05 AM
durf durf is offline
Calculating Speed with sensor
Right now I am trying to figure out how to calculate speed with a sensor. I know that speed is the rate of change with respect to time. So change of position / time.
I know I need to get the position(pos) of the sensor first. Then i have to have a def: that will check for its new pos then do the calculation - (new pos - old pos) / time. Then after that I need to start over and set the new pos to old pos.
The problem im having is trying to establish a pos before the def: starts running. Whenever I test for the old position i keep getting 0.0, 0.0, 0.0.
So its going to look something like this:
PORT_PPT = 6
for x in range(1):
     #Create sensors
     ppt1 = viz.add('vizppt.dls')
     ppt2 = viz.add('vizppt.dls')
     ball1 = viz.add('white_vall.wrl')
     ball1.scale(1,1,1)
     ballLink1 = viz.link(ppt1, ball1)
     ball2 = viz.add('white_vall.wrl')
     ball2.scale(1,1,1)
     ballLink2 = viz.link(ppt2, ball2)
     #controls distance in virtual world
     ballLink1.postScale([8,1,13],target = viz.LINK_FULL_OP)
     ballLink2.postScale([8,1,13],target = viz.LINK_FULL_OP)
#I need to check for ball1 pos before here
def speed():
      #need to check for new pos for ball1 here
      #need to somehow get old pos of ball1 so i can do the equation
      #new pos - old pos /2(=1/2 second)
      if speed > 1:
           #some reaction happens in here
      #need to set old pos = new pos
vizact.ontimer(.5, speed)
Ive been trying to write this to work without errors but i keep getting them. I still new to vizard and python so any explanation would help also.
