The viz.gravity command changes the force of gravity on the viewpoint when viz.collision is on. This will not help you with your pillars =(
But, there's hope. You can use Vizard's physics engine to move the pillars. There are tutorials in Vizard's help that will get you started with the physics engine.
If you just need the pillars to fall and sit there all nice and stable you could move them manually each frame with a timer and this physics function:
yPosition = initialPosition + initialVelocity*secondsPassed + .5*gravitysAcceleration*secondsPassed*secondsPasse d
For the pillars this function would probably look like this:
yPosition = 0 + 0 + .5*-9.8*secondsPassed*secondsPassed
Paul Elliott
WorldViz LLC
