Old 03-03-2009, 12:59 PM
durf durf is offline
when a sensor moves over some other object
Still kind of new to python language.
Lets say I have a "white_ball.wrl"(ball) that is linked to a ppt sensor. And I have a block that is located at position (10,0,0). What I want to happen is if the ball moves over to position (10,0,0) the block will have a new set position at (10,-10,0). The ball can be at any level on the y-axis by the way. I only want to worry about where the ball is on the x and z axis.
What I need to know:
What do I have to do to compare the position of the ball == to the position of the block(keeping in mind that there is a surface area on the block of unknown size.)?
After it compares the two to see if the ball is over the area of the block, how do I set the position of the block.
Any help will be much appreciated.
Thank You
