Old 08-13-2004, 11:21 AM
tavaksai tavaksai is offline
clarification
Hi Farshizzo,
I don't think the group method helps. It has the same problem.
Just to clarify what I meant, here is a sample code:
outer_tube = viz.add("outer_tube_97_m.wrl")
# rotate around original 0,0,0 center
outer_tube.rotate(40,0,0)
print 'first position:', outer_tube.getpos(viz.ABSOLUTE_WORLD)
# don't want this next call to change position of object until next
# rotate call is made
outer_tube.center(.6,0,0)
print 'second position:', outer_tube.getpos(viz.ABSOLUTE_WORLD)
Notice first position and second position are different.
I would like second position to be equal to first after .center call.
In other words, I would like to prevent the object from moving
in any way upon obj.center(...) call.
I would like it to move only when rotate or translate functions are called.
Thanks for the help so far ,
Max
