Thanks for the quick reply (you've saved me a lot of time!)
The only unclear thing is the following line:
songCycle = viz.cycle([ viz.addAudio(filename) for filename in songs ])
It will load the songs as it is or I have to change something? (ie replace the "filename" with the first (actual) filename in songs?)
I also met another problem. I had these errors when I run the code:
File "C:\Program Files\WorldViz\Vizard30\python\viztask.py", line 685, in _onupdate
self._tasks = [ t for t in self._tasks if not t.update() ]
File "C:\Program Files\WorldViz\Vizard30\python\viztask.py", line 652, in update
val = self.__stack[-1].next()
File "museum.py", line 78, in PlayMusicTask
songCycle = viz.cycle([ viz.addAudio(filename ) for filename in songs ])
File "C:\Program Files\WorldViz\Vizard30/python\viz.py", line 7524, in addAudio
return VizAudio(_ipcSend(_VIZ_ADDAUDIO,0,0,fileName,0.0,0 .0,0.0,0.0),**kw)
TypeError: message must be a string
