Inertia Cube 2 initilization
We found that when vizard loads intersense IC2 by "viz.add('intersense.dls')", it always set IC2 with compass ON even we turned the compass OFF in isdemo(and save it to the memory to replace the factory settings), which is undesirable in many applications.
is there any command to communicate with IC2 to solve this problem in vizard? thanks.
