I've done a little more debugging on this problem and I find that I have the same problem on another machine that has the ATI Radeon 9700 card on it. I am using the digital and analog outputs for a dual monitor setup and the OEM provided drivers. So perhaps the problem is not Quadro card specific.
When I use viz.go(viz.FULLSCREEN) the display spills over partially onto the second display. Using HMD|STEREO modes is messed up as well.
On the other hand, when I use a GeForce4 MMX dual headed card, I don't have a problem. I noticed that the GeForce4 driver treats the two monitors as a single 1280x480 monitor rather than using default Win2000 multi-monitor support (which is used by the other two setups)
Unfortunately, I don't have any PCI cards around with which to test this with two separate cards.....
Any luck debugging from your end?
Andy
