Old 02-11-2009, 06:54 PM
nlfrnassimi nlfrnassimi is offline
Thanks for your help. Still I'm having problem with giving value to translate. when I assign value to it, the ball suddenly disappears.
Please check the code.
viz.clearcolor(0.5,0.5,1)
soccerball1 = viz.add('soccerball.ive')
soccerball2 = viz.add('soccerball.ive')
soccerball3 = viz.add('soccerball.ive')
soccerball1.translate(-1,1.5,3)
soccerball2.translate(0,1.5,3)
soccerball3.translate(1,1.5,3)
arrow = viz.add('arrow.wrl')
arrow.scale(.1,.1,.1)
arrow.visible(viz.OFF)
def mouseclick(button):
global ball
pickObj = viz.pick()
if pickObj.valid():
ball = pickObj
ground.disable(viz.PICKING)
def myTranslate(key):
global ball
if not ball:
return
if key == viz.KEY_UP:
ball.translate(0,1)
elif key == viz.KEY_DOWN:
ball.translate()
elif key == viz.KEY_RIGHT:
ball.translate()
elif key == viz.KEY_KP_LEFT:
ball.translate()
vizact.whilekeydown(viz.KEY_UP,myTranslate,viz.KEY _UP)
vizact.whilekeydown(viz.KEY_DOWN,myTranslate, viz.KEY_DOWN)
vizact.whilekeydown(viz.KEY_RIGHT,myTranslate, viz.KEY_KP_RIGHT)
vizact.whilekeydown(viz.KEY_LEFT,myTranslate, viz.KEY_KP_LEFT)
viz.callback(viz.MOUSEDOWN_EVENT,mouseclick)
viz.mouse(viz.OFF)
