method works
Hi guys,
I implemented the method you came up with
and it worked pretty well.
The only minor issue is that if the user violates
the constraints, there will be some "weirdness"
going on in the virtual environment. For instance,
if you DO happen to raise a hand above the head,
the view position will temporarily be controlled by
the hand. But, it works ok.
Max
