  #17
Old 02-10-2009, 02:10 PM
You probably have another Python installation on your computer that is interfering with the Vizard installation. Run the following script and post the output. If the output contains any directories that are outside the Vizard directory, then that is most likely the problem.
import sys
for p in sys.path:
	print p
